ON1-IIC "Blasphemy" (3xcATM9, 3xcMPL, 1xcAMS, cAP, TC1, cXL350)
1 rating
Thread in 'ON1-IIC' started by CarloArmato, Aug 14, 2017.
  1. CarloArmato
    This build is blasphemous because it breaks the untold rule "Orion IIC can only brawl".
    This build is best used in the 120-270 meters range for maximum ATM damage. In that range, you will have a better alfa strike than most brawling builds, but of course you can't have the same DPS. Over 270 you will have 2 instead of 3 damage per missile, so you should use it sparingly depending on the target. Lights and Mediums are your best bet because they will crumble in no time despite the lower damage but most importantly because they are the one which can get close to you easily.
    Medium pulse lasers are used both to pinpoint some damage and to fend off incoming light. Because they are mounted on your arms you can easily track lights and mediums which happen to be under 120 meters and inside the safe range of your ATMs
    Nekromanteia and Excalibaard like this.
  2. Excalibaard
    5,169
    I love it! ATM salvos of 72 damage each in 270m is technically brawling, right? :D
  3. Excalibaard
    5,169
    My first game in a variant of this monster. Yes please!
    Note that in-game the legs are still at 53 armor
  4. TheKildar
    TheKildar New Member
    I've been in love with almost anything that can carry three atm 9's for a little while now and they are nicely concentrated together on this mech's hardpoints, I also like it because i enjoy mechs that can be run with just two weapon groups and it is often hard to do that with the Orion.
  5. Nekromanteia
    Nekromanteia Benefactor
    45
    1st game with no skills, build is looking good imo
