NVA-P "Jack in a Box" (2x cERPPC)
1 rating
Thread in 'Nova Omni Builds' started by Remarius, Jun 19, 2014.
  1. Remarius
    Nice little poptart. Enough heat sinks to fire essentially continously. As standard shield with your mostly empty side. Can go left and righty if you want but I prefer the focused attack on one location and ability to shield. Its an agile little mech so easy to relocate to fire.
    Solahma's updated version for the new omnipods (currently $ only as of 27/01/2015). Vulnerability is hugely reduced and hard points are higher. Less aiming capability as fixed but definitely better:
    McGrizzled likes this.
  2. Remarius
  3. Cpt Chattahah
    Very nice. I'll have to give this a shot. May just replace my Shadowhawk Jump Sniper build for a bit. It's always nice to have actuated arms for your weapons.
  4. Fallout
    Fallout New Member
    I've had pretty good luck with the NVA-B by replacing the ballistic arm with a NVA Prime and put two C/ER PPC on it. Heat management is pretty good. If anyone has suggestions to make it better I'm all ears.
  5. Durandal
    I was messing around with a similar build (theory anyway, haven't made it reality yet) that removed some of the heat sinks (by using the Prime RT/LT), but added in some ERSLas. While it runs hotter, it gives a lot of added power to the mech against lighter mechs that get in close, and if only using the PPCs OR the ERSLas, the heat would be more manageable. The only problem I see with going with the 2 ERPPC build and nothing else is that any Jenner/Ember that gets near you is going to be a serious problem, whereas a build with more lasers offers a fairly decent defense.
    Still, works decently as a sniper or even a Nova Poptarter, so whatever floats your boat ;)
  6. Solahma
    Few changes with this build. I have min/maxed it to make full use of the new omnipod quirks:
    NOVA
    NVA-PRIME LEFT ARM
    • ENERGY HEAT GENERATION: -5.00 %
    NVA-PRIME LEFT TORSO
    • TORSO TURN RATE (YAW): 10.00 %
    NVA-PRIME CENTER TORSO
    NVA-PRIME RIGHT TORSO
    NVA-PRIME RIGHT ARM
    NVA-B LEFT ARM
    • ARM MOVEMENT RATE (YAW): 5.00 % ARM MOVEMENT RATE (PITCH): 5.00 %
    NVA-B CENTER TORSO
    NVA-B RIGHT TORSO
    • TORSO TURN RATE (YAW): 5.00 %
    NVA-B RIGHT ARM
    NVA-S LEFT ARM
    NVA-S CENTER TORSO
    NVA-S RIGHT ARM
    NVA-A RIGHT TORSO
    I separate the cERPPC to either side in-case a torso is taken out. Plus, the arms are the biggest target on this mech, you will lose that Arm mounted cERPPC more often than not.
    TC1 for velocity and crit buffs.
    "S" or Prime arms provide a cumulative -10% heat generation
    Prime CT increases twist speed 10%
    Prime LT increases twist speed 10%
    "B" RT for the energy hardpoint and another increased twist speed 5%
    That's a cumulative +25% twist speed! Pretty significant with it's smaller 250 engine.
  7. skribs
    skribs Min-Max Maniac
    1,690
    Both sides also lets you peek left or right. Boating on one side means you have to expose 100% of your mech to shoot around some corners.
    It's all a tradeoff.
  8. Solahma
    True, mounting them both in an arm means you can hug a corner in that direction very well, but very poorly in the other direction. You also have the benefit of arm actuators. On the other hand, the torso mount is much higher than the arms, so that cERPP can easily be used to peek over terrain. It's also very close to center so peeking off to one side is just about the same. It's also for durability reasons because it is A LOT more difficult to lose a torso then it is an arm on the Nova.
  9. Durandal
    I do like running a Nova like this from time to time, though I go with the torso point more often than not. Being able to peek-a-boo just over a hill and fire a PPC is a handy tool to have.
  10. Remarius
    Can't pretend I thought much of them when I ran them out again compared to some of the new IS quirked ER PPC mechs. The dual ER PPC just generates too much heat to easily soak up with a 10% heat bonus.
    Revealing the whole of your mech to fire your only two weapons seems suicidal nowadays in such a slow moving mech unless you're poptarting and strangely the Nova just felt clumsy in the air - weird as the Mist Lynx with just one more JJ feels incredible in the air. On the ground its .... clumsy...
    Irony that my heavy TBolt feels more graceful.
    The 12 ERSL 4 MG version worked well in groups at least.
  11. Solahma
    Hmmm I think of the Nova to be probably THE best jump sniper in the game right now. Very good turn rates, very good Juno height and speed, also it is a MEDIUM and can field builds usually reserved for heavies, A LA Nova tart for example. Comparing the effective firepower of a 65 ton heavy to the Nova just shows that this is one BADASS medium.
  12. Solahma
    New omnipods allow for both cERPPC to be mounted in the side-torsos and strip the arm armor a bit. Much better hardpoints for this mech.
  13. Remarius
    Heres an interesting dynamic though - would you use the 10% heat gen reduction from the Prime arms or the 10% cooldown bonus from the A arms?
  14. Motörhead
    With 18 DHS, heat reduction all the way.
  15. Solahma
    What he said. I've run a few times, it is nearly un-playable on a hot map even with the 10% heat reduction.
  16. Remarius
    Mmh thats interesting as I've not had much problem but it very definitely isn't a brawler.
  17. Solahma
    I'll double check I got the arms right for the heat generation and my skills, but I'm pretty sure that I got the double-basics with GXP so i didn't have to wait. Was fun, especially on cold maps, but on hot maps like Terra Therma it was PAINFUL. More than I personally could enjoy. I kept thinking, I have a better time in the Nova Tart with 1/2 the armor...
    I really enjoy the TBR with 2x cERPPC, but that build has ~5 more DHS and is still hot enough to be careful with your shots.
  18. Remarius
    Oh agreed its a pig on TT. I find a lot of builds follow that pattern and I generally loathe that map coming up unless I'm in a ballistics heavy boat.
    Edit: I will say that for me the inability to vent heat in the air really hurt builds like this which are energy pop tarts.
  19. Solahma
    Remarius likes this.
  20. enileph
    This would be a better title also.
