NVA-A "Scalpel" (6xcSPL, 6xcERuL, 4xcMG, TC1)
Thread in 'Nova Omni Builds' started by ShooterMcGavin80, Sep 26, 2019.
  1. ShooterMcGavin80
    519
    Short ranged, but boy howdy this thing can do some damage when up close in your face.
    SPL/ERuL/MG's have a nice range synchronicity. Get to about 150 meters and you can melt an enemy quite nicely. And while you will run hot in extended combat, you can still keep the DPS running pretty continuously. Short burn time means you can pick out components nicely. Every 2.25 seconds you can put close to 38.4 points of laser burn onto a component.
    Suggested skill tree:
    https://kitlaan.gitlab.io/mwoskill/...fe271fcff7f0000e86f1300000080af271b#s=Weapons
    You could go 15% range nodes to try and give your short range weapons a little extra reach, but honestly I think the extra 15 meters is less valuable than the agility and survival trees.
    TC1 is optional; thought is that if you're firing 12 laser weapons, the extra crit chance will help out.
    I'm building this on the Breaker, but can be done on any standard Nova.
