Nice. The build I use is very similar but with a couple differences. For me its all bout balance and symmetry. Not certain the benefit of having cAP. Heat sinks let me spam ERLL and rarely need more than 50 rnds but if I did I could replace a HS. Using ammo as crit padding and while I like the head slot I typically only use it when I run a single or triple ERLL build...OCD ftw
ECM available. _ Risky, higher alpha version Requires full skills with careful choices for decent results. _
5/5, This is one of the solid meta NTG builds. 2xERLL, 2xGR, ECM on the 'H'. Also possible to do 2xGR, 1xERPPC. I personally prefer the 2xGR, 2xERLL version, has more DPS and better alpha. The 2xGR 1xERPPC is slightly more stealthy, sometimes it is harder to identify where a single ERPPC bolt is coming from versus two large blue lasers beams, which pretty much give away your position.
