Nanuq 'Dark Knight' (1xATM6, 2xcUAC10, 3xcERML)
Thread in 'Nanuq' started by Aylek, Aug 6, 2017.
  1. Aylek
    Originally coming with an LRM 15, the ATMs definitely fit more to my play style on the Nanuq. Therefore ATMs finally let me abuse the quirks and bouses coming from using 8/8 omnipods on several variants including this one:
    Regarding the loadout, after using several different setups on the Nanuq including usinge a Prime or C left arm with dual UAC5 + dual ERPPC, I finally came back to the dual UAC10s + ERML. They are matching nicely range wise, and triple cERML are sufficient backup once the ammo count gets low for the UACs. The freshly introduced ATMs are the icing on the cake, adding a lot of damage within the preferred range up to ~ 550m. Giving this a second look, 2t of ATM ammo might be a bit excessive. Shaving half a ton and adding a light active probe might be more appropriate here.
    Here is my current skill tree for this build. It's definitely not optimal yet, but works for the build.
    https://kitlaan.gitlab.io/mwoskill/?p=jsonbin1.59869ee321c43a3370233851&s=Weapons
    Surprisingly, the Nanuq has become one of my most reliable CBill earning machines. Must be because of games like this one:
