Casual MDD-H 'Rain of Fire' (2xATM12, 3xHML, 1xcTAG, cAP)
Thread in 'Mad Dog Omni Builds' started by Aylek, Aug 16, 2017.
  1. Aylek
  2. Excalibaard
    5,057
    1,108
    Absurd. I'll have to get this MDD. I love the distinction between the HML and TAG arm as well.
    Aylek likes this.
  3. How is the heat with the missile cooldown quirks?
    I tend to run a lot more cooling skills.
  4. Aylek
    Although having more than 24k GSP lying around I tend to level new mechs the classic way, at least partially. Therefore I can't give you a comprehensive answer yet. After some matches I found ammo to be a bit short, so I switched to HSL instead of the HML in favor of additional ammo.
  5. Excalibaard
    5,057
    1,108
    Ammo is short, yes. <20 salvos, with 30% Missile cooldown quirks. I'd try to get around 35-40 salvo's (25/0.7=35.7, and I try to equip 25 salvo's on mechs without CD quirks). Using missile rack skills, and probably by going down to a 12 and a 9 (or 2xATM9). This build has 36 salvo's with missile rack.
  6. Shock
    872
    354
    On my ATM9x3 Mad Dog, I bring 800 missiles and have managed to run out. With that cooldown boost, I would expect that ATM12x2 would need similar ammo levels
  7. I find that ATM ammo count is very dependent on Range Discipline. If you wait until you can see the whites of their eyes 800 missiles is 2,400 damage.
    If you are firing at 550+ you are going to burn through ammo fast and have a much lower hit percentage.
  8. Aylek
    Seems as if there are slight problems applying targeted damage and securing kills... :D
  9. Excalibaard
    5,057
    1,108
    I moved the tag to the left arm, removing 1 HML. Removed tonnage from my RA and that way mounted plenty of ammo for dual ATM12, while keeping the range and improving the heat profile!
    I have a recording where I played this during community drops in Baradul's stream. 1100 damage without strikes, just because I could fire down a hill with TAG assistance. I'll try to find the time mark.
    Valistan likes this.
  10. Ragnahawk
    Ragnahawk Well-Known Member
    219
    This explains why my locust vaporized to a maddog.
  11. CabooseR
    CabooseR New Member
    This build is amazing. I've consistently topped 1k damage with my highest at 1226. Probably 6 of my first 20 games were over 1k with another 10 or so between 600-800. ATMs are amazing.
    Aylek likes this.
  12. Valistan
    Valistan New Member
    Very Good build. My result is here
  13. TheOddball
    TheOddball New Member
    Good build. Bought the MDD-H specifically to try this.
    Aylek likes this.
  14. IronEleven
    IronEleven Active Member
    Made room for an extra ton of ammo downgrading the TAG and reducing armor on the associated arm, It breaks off pretty quickly but to me it beats sacrificing firepower.
  15. Falconium
    I generally use a Light Tag with my ATMs as well. Because the range coincides so well with the ATM mid-damage range, it makes for a nice fit. You don't want to remove ECM on targets beyond 500 meters anyway, it'd be a waste of ammo to fire on them. ;)
    You can put another 10 points of armor on that right arm by dropping 10 from the head. I know it's generally considered bad form to reduce head armor that much, but the Maddog head is almost impossible to hit, even by accident. Worth the risk in my opinion, to keep the tag arm.
    IronEleven likes this.
  16. IronEleven
    Honestly not sure why I overlooked the head, it's usually one of the first things I strip for spare tonnage.
