Similar and inspired by https://mechspecs.com/threads/mdd-rv-regretdog-2xchll-4xcsrm6-6xcerml.14317/#post-94964. Posting this here as no hero pods are used and slightly different playstyle. RegretDog focuses on engaging at 450 meters with lasers only and using SRMs as backup weapons. This build focuses on full alpha inside of 300 meters. Plan your shots carefully as you will be very vulnerable until you cool off. Please take all the heat skills, laser duration and ammo skills. Cooldown skills are less important, but helpful for follow up shots with SRMs or engaging at mid range distances with the HLLs. FYI cSRM2s have a spread of 3. cSRM4s have a spread of 4.5. cSRM6s have a spread of 5. It is less heat to go with another pair of SRM4s over (4) SRM2s and you can move ammo to the legs. Up to your preference for spread vs heat. You can get the SRM4s to the top of the side torsos for hill peaking. Also make sure you arms clear hills/obstacles before firing. You don't want to waste any heat on blocked shots. Override wisely.
