Casual MCII-DS "One tap" (2xcLBX20, 6xcMPL, cXL325)
Thread in 'Deathstrike' started by CarloArmato, May 17, 2019.
  1. CarloArmato
    1,727
    509
    Hot high alpha brawler build with decent speed. Its Iow on ammo because you need all the cooling you can get and you should be aggressively poking with this build, you should not start a brawl you are not sure to win on against a fresh mech.
    79 damage alpha strike means it's almost identical to my young chuck norris annihilator (2xHGR, 6xML) and still similar to "One punch anni (2xHGR, 6xMPL), hence the name "one tap"
