After some research and thanks to @anamiac that pointed out how low is the ghost heat of 2xMRM40, I've decided to try out this one... And it melts faces below 100 meters, despite being somewhat slow. With this build, you get a nice -10% laser heat generation, so you can boat 6 of them without much trouble... In fact, you should be cooler by permafiring only those 6xML instead than chainfiring MRM40s... Also, those arm-mounted lasers will help against fast mechs. Spoiler Don't forget about quirks and skills: smurfy does not consider them. As weapon groups, I really recommend at least the first 3: Laser alpha strike MRM alpha strike MRM chain fire (use when heat is over ~60%) Laser chainfire (in case of flamers / extremely hot and life or death situation) First drop with this build (skills already maxed): 1100 damage, 4 kills, 5 KMDD, 2 solo kills, 7 assists... And I runned out of ammo right at the end! Spoiler
