MAD-IIC-B "Big Brother" (2xcLPL, 3xcERML, TC1, cXL400)
1 rating
Thread in 'MAD-IIC-B' started by Spheroid, Dec 15, 2016.
  1. Spheroid
    Spheroid Well-Known Member
    202
    The same generic laser vomit you can run on the Timberwolf or Ebon but beefier. In some ways better since you have both arm actuators. As a bonus you can use surplus 400XLs from your Kodiaks.
    You can also add ferro, I didn't install it because I might play around with other builds. You gain 2.666 tons and have five free slots remaining .
  2. Tank the Frank
    Tank the Frank Benefactor
    100
    I run a similar build on the IIC but with a std 340 engine and 5 ml:
    The IIC allows you to zombie if you lose both side torso's, and I have a shield arm.
  3. krevLL
    krevLL Insane Fire Troll
    396
    126
    153
    This is how I built my B, and this is probably going to be how it stays. Fast and effective at anything other than knife fights with fresh mech's. I may swap the RT medium for an ERLL at some point with FF armour, but the gist remains the same. Excellent build.
