Casual MAD-6S "Hot Handed" (1xLBX20, 2xSNPPC, 4xMPL, 1xJJ, TC1, STD300)
Thread in 'MAD-6S' started by Dagonus, Mar 26, 2019.
  1. Dagonus
    453
    115
    156
    The Alpha is 70% of your heat capacity, but you should be able to lay on the LBX for those situations and then use the other weapons more sparingly. Should give you a nice punch though; especially if you can fight around a corner.
  2. AluminumJacket
    AluminumJacket New Member
    This build right here is my absolute JAM. I have the LBX20 w/ 6med las on my MAD BH2, and its the strongest heavy mech in my inventory. This is just a scaled up version of that.
    Only complaint is that the range is pretty short, but once you get the skills up, its no issue.
  3. RoboCriminal2
    RoboCriminal2 New Member
    I dig it, though I did mess with it a little bit. Regular mediums instead of pulse lets you get away without the Light-Ferro and runs a bit cooler with an extra ton of ammo.
    Dagonus likes this.
  4. Dagonus
    453
    115
    156
    MLs looks like a really reasonable trade for the cooling improvement.
