MAD-5M "Double Barrel" (2x LBX10, 5x ML, 1x JJ, STD300)
4.66667/5,
3 ratings
Thread in 'MAD-5M' started by Blagg Zear, Dec 11, 2015.
  1. Blagg Zear
    Well, since no one tried this out. Here it is - the Weaponloadout that makes a Big Bang in your ears. Ready to hunt some deer!? :D
    Weapon Groups:
    1. PewPew (linked)
    2. Double Bang (linked)
    3. PewPew (chainfire)
    Test Run:
    Blagg
  2. Patham
    Patham New Member
    axe one m-las and that's pretty much what i run on my 3R.. pretty effective :)
  3. onebit
    onebit Benefactor
    Experimenting with dropping 1 ton of ammo or ML to raise the armor back up to 448. It's nice having the jump jet, but the build fits the 3R better.
  4. enileph
    Why? ammo is tight as is? But if you choose to do that you can raise the armor to full instead of 448, and get an extra DHS
    Also you can also drop one ML instead, how I ride.
  5. Regina Redshift
    1,293
    This is pretty much how I plan to run mine.
  6. AceOfSwords
    AceOfSwords New Member
    if ammo is a problem, and if you want to pack more punch, you can drop the engine down to a 260 std and lose the jump jets. it basically is then a 3R but you can play a little more with ammo, tossing some for a jumpjet or two. once you lower the engine, you can upgrade the mls to mpls and add about 3 tons of ammo. Of course, you could keep the mls and the jumpjets if jumping is really important to your playstyle.
    here's a modified version based off my 3R
  7. germs95
    germs95 Junior Member
    Who does not like shotgun????
  8. two birbs
    two birbs New Member
    I love this build! I run it like this, and do not regret dropping the JJ for a second.
    Blagg Zear likes this.
