I don't find the PPC quirks that amazing. Yeah, easier to aim with 50% extra velocity, but only 10% heat reduction? I figured this would be a fun alternative for building a sniper. If you want you can have both ERLL in the same arm for convergence. Plenty of ammo for the high mounted Gauss, the ERLL are mounted a bit low so heat should be fine when near cover. Building process: - Decide that I want a high Gauss and that Marauders are cool. - Preferably keep the same engine as the mech starts with to save costs - Add 3 t of ammo - Fit Endo because I'll likely have the crit space - Add 2x ERLL, then 2x ML as backup weapons. - Fit 2x DHS to support ERLL(+ML) - Increase armor - Fit FF because I have the crit slots - Add extra DHS and extra ton of ammo - See that I have 1 crit slot left, and split 1t of ammo into 2x ½t for critpadding.
For me those 50% velocity combined with -10% heat reduction makes this variant tick for me. The only build I'd give those up on the 3R is the 3x AC5 + 4 MLas one - If only I wasn't using 3 AC5s on my Black Widow already....
3x AC5 +4 MLas is also what I'd run, like a mobile Banshee. But I wanted to build something different
