Hello all Here is one of my favourite CPLT K2 build : I like to play to it as I found it versatile and quite efficient I have a Jester chassis and I would like to find the same feeling with it. Any suggestion ? Thanks a lot !
You obviously won't be able to use the autocanon, but here are two builds I made with PPCs : (thread) (thread) To be honest I haven't pilot them for a long time (not post quirks). Another build I enjoyed is the 6 MPLas: The quirks are mostly versatile, but there is a slight edge given to LLas, so here is a 4 LLas build: Anyway, I suggest you take advantage of the double AMS (1 ton is ok, 2 tons might be needed if you use the modules) and the jets.
This morning I swapped my build back to 3 PPCs to see how its working now, and it works great. -10% heat generation (and PPC heat changes? I don't remember) made it much more manageable than for my memory.
I would suggest the MurderWagon build... PPC and JJ to hop and snipe, LPL to complete mid-range and finish in close. Dual LPL will tear off light's legs like nobody's business. Good build to keep a mix of sniper and brawler. The UAC5 is hard to match, but, for a JJ, I'd take the trade in cooling efficiency, speed, and mid-range alpha. Or go closer range and take the brawl to FULL advantage of those small Side Torsos with a big XL, lots of energy firepower and decent cooling! Chatt.
