The build is fairly silly; but as far as shoot n' scoot; it's effective. Think the old ERLL builds; and now slap on a weapon that's harder to trace. Basically; the build is fairly obvious. See a target at long range? Slap 'em with the Light PPC. Won't really do much; considering the low damage, but it's a low cooldown weapon that can fire as fast as your medium lasers. Now, once you get into close range with damaged targets, that's where you use those medium lasers to finish them off. Small Pulses and Small Lasers are both options here, depending on how close you want to get and how many shots you want to take in close. I'd personally recommend against ER Mediums, though - the extra heat and burn time can be problematic.
I built my 1V around an LPPC, and I've had good success with it. I normally don't dig SPL, but I think they'd work on this mech. They could make another light truly regret closing within 90m.
