LBK-C "Striker" (1 cGauss, 4 cERML)
Thread in 'Linebacker' started by Aramuside, Nov 18, 2016.
  1. Aramuside
    Aramuside Star Lord
    304
    Weaponry all torso mounted for protection. Has to sacrifice all arm armour and the TC1 I'd have liked to fit in but nice firepower on a fast chassis.
  2. Aramuside
    Aramuside Star Lord
    304
    Just to update, I've ended up running this on the B as well so with3 ER ML spread over the arms. Bit more accuracy but you occasionally lose a laser or 2. Advantage is it has better quirks for the current skill tree. Armour enhancement on all three torso areas (the C has structure on left and right) and strangely the right arm then structure on. Structure enhancement on both legs. Turn rate of +15% which makes the "wiggle" move to spread damage and cornering very easy. Acceleration and deceleration +10%. Its only weapon quirk is -5% ER Laser duration but then the C has none at all.
    This is the tree I've been using and its behaved very well so far.
    https://kitlaan.gitlab.io/mwoskill/?p=d0e3f179-5d22-11e7-ae4c-1f0c172c6a3b&s=Miscellaneous
