Fun for brawling, poking, prodding, all sorts of fun stuff. Good for mixed range maps. Consistent 4's and 5's, a few great matches. Apparently 762 is my lucky number. http://i.imgur.com/TRzCx5s.jpg[/img]
Doesn't really have ammo problems, 3 tons is plenty for 2 6 packs. If I were to run 3x4's i would need to armor up the left arm, and I fear that it might start running into heat issues, as 3x4's hits ghost heat.
Ghostheat comes on the 4th SRM launcher. So no ghostheat. But yeah, it is a choice between armor and DHS. You are right the ammo should be fine, was mistaken the ammo count for 2 tons.
No, you get the first mild ghost heat with the third, then full on ghost heat with the fourth. Its already at 1.2ish, I wouldn't want to drop more heat sinks for when I get into brawly situations and need to fire as often as I can.
