KGC-0000 'Volcano' (3x ERLL, 4x LRM5, 2x AC2, XL350)
Thread in 'KGC-0000' started by Sir Tiddles, Feb 5, 2015.
  1. Sir Tiddles
    Sir Tiddles Active Member
    96
    The thing I like best about the KGC are those high energy and missile hardpoints for peeking over hills. This build is an attempt to utilize that fact as a long range harasser. With this build the point is to peek your head out, snipe with the lasers and fire the missiles as you back away out of sight. In more open areas, chainfire AC2s and chainfire LRMs gives lots of screen shake while you relocate to a new place of cover. It is hella hot if you're trying to fire all the things, but it will put out some solid dps with lots of screen shake if you only use the lasers for sniping and when you are OOM.
