KGC-0000 "King of the Hill" (4x LLAS, 2x Gauss, XL325)
Thread in 'KGC-0000' started by Lan, Jan 21, 2015.
  1. Lan
    Lan Mech Wrangler
    1,570
    Yes, it's a XL. Yes, it's two Gauss rifles. It's a bad idea but you know, sometimes even bad ideas needs testing. :)
    Recommended modules: Radar dep, Hill Climb (seismic is not a bad idea for this slow poke), Gauss cooldown, Large Laser cooldown.
    Recommended role: Line fighter, multi role (very limited tank)
    Recommended playstyle: Only use this in a lance, frontload your armor, hug those hills and use those high mounted lasers to fire over obstacles. Set right and left arms on separate buttons and fight around corners, prefer to fight righthanded or on slopes leaning to down and right as you can peek with max efficiency. Push the enemy down and hold that hill so your lance can advance. Do not go head to head with other assaults without backup, you are a bomb waiting to explode so use your armor wisely and engage at 4-500 metres range.
    Screenshots taken while still earning basic skills, surprisingly efficient but then dual Gauss are mean.
    Edited original build by splitting gauss ammo into half ton sizes for critpadding. Also frontloaded armor heavily.
  2. schnaetz
    schnaetz Benefactor
    247
    You could split up some gauss ammo for critpadding of your side torsi (?)....anyways: :eek: scary
    I would also add some ammo and lower leg armor a little bit..but that's just because I like waisting shots ;).
  3. Lan
    Lan Mech Wrangler
    1,570
    Yeah, thought about splitting ammo but I didn't for some reason. Updated OP with a screenshot or two.
