I saw a guy run a King Crab very effectively with a massive 12000+ load of MG ammo, firing constantly. Very entertaining. He stripped armor with MRM's and lasers, then relentlessly went on with 6 MG's. Here's my adaptation of this: Here's an alt with LPL's: (Hotter, more armor stripping POWAH!!)
Minor modifications. Less LMG ammo, more MRM power and ammo. I pair the MPL's with the LMG's, and they're basically heat neutral. Check out those DPS numbers.
Since then, I've changed the MRM50 into MRM60. This is designed to have an insane amount of LMG ammo so you can always be shooting. You could also swap a ton of LMG ammo for more MRM ammo. _
_ I would move the ammo around a bit to make sure you have MGs going at the end of the match even if you lose a leg. I added a heat sink. You could add in more ammo or another heat sink if you can get by without AMS.
Shorter range standard engine alternative. You can upgrade to MPL at the cost of the engine or cooling. _ _ Kind of fun to play with the right map.
