Seems to be pretty efficient. Strip armor with lasers and the huge cannon and then tear the internals apart with MG. Any comments are welcome
This is a great build. The mix of an AC/20 and dual LL is phenomenal without any extras. The damage to range is just fantastic. My only suggestion would be to try a STD engine. Jagers are such unique mechs in the fact that they are quite fragile with an XL (while still incredibly deadly) and yet, so robust with an STD. If you drop your 2x MLas and the extra DHS, you wind up with a solid 38 point alpha with 2 additional crit seeking MGs, raise your cooling efficiency to 47% when mastered, top speed of 74kph and can pad that leg armor, added to the STD - giving survivability out the hindquarters! http://mwo.smurfy-net.de/mechlab#i=67&l=e4a074fc810ed9b198436576a89e45a4839df094 Either way, a very solid build. Either speed or longevity.
Hmmm, this is a brutal Alphastrike-Skirimisher Build! Simply walk into someone's Face, Alphastrike and then run away, wait for Cooldown.. and then return, Alphastrike! Do this several times, and even Assaults will fall within seconds. Let me tweak it a little:
