Was trying to run this build grouped with someone at mechspecs before I got kicked out of the game by error, so here it is. I hate how often I get d/c before I join a game. This is a small upgrade from stock. Mostly higher armor, and using SRM4 for a better grouping. Oh more ammo and a better beam weapon in the form of LLas allowing for a longer strike range. Since FF is not worth it alone you will have to shell out 750k to swap it to Endo. But the cost is fine other than that. REAL Smurfy will follow when it is updated. For now *imagine* adding 2x AC5 and 4 tons of ammo. Type 2 with 2x UAC5 with 4 tons of ammo instead.
