Ilya Muromets "Argos" - Medium Range Striker (3x AC5, 3x MLas, XL320)
Thread in 'Ilya Muromets' started by TruePoindexter, Dec 27, 2012.
  1. TruePoindexter
    TruePoindexter Active Member
  2. Marukeru
    Marukeru Benefactor
    This should be moved to the appropriate subforum.
    That aside, interesting build :)
  3. TruePoindexter
    Opps! I'm going with the "it was late and I was tired" defense.
    Glad you enjoyed it though! :smile:
  4. Darkhammer
    Darkhammer New Member
    Looks similar to mine, but i'm using only a 295XL and 3 UAC/5 /w 150 rounds of ammo + 3 M-Laser as weapons
  5. twibs
    twibs New Member
    Yup, almost same here. XL300, AC/5, 2 UAC/5 and 3 MLAS. 2t AC/5 ammo, 5t UAC/5 ammo. It works like charm. Just for the love of god don't store your ammo in middle torso.
    With 3 normal ACs you see a distinctive gap in the firing cycle, but upping two to UAC there's much better DPS, bullets being fired at almost constant rate. This build can cope with surprisingly few heat sinks, I believe I only have 12 or 13 DHS.
    And for the previous poster, 150 is not enough for 3 UAC, try to get more.
  6. ScutMonkey
    ScutMonkey New Member
    I tried the OP's build but I can't get fit the third AC/5 on there. Has something changed in the weight of an Ilya?
  7. Tuku
    Tuku Well-Known Member
    217
    Maybe you did what I did....I had a standard instead of XL engine in the thing :p
  8. Tuku
    217
    I just tried this build and I like it because, well I am an atlas pilot at heart and this thing while not as well armored pilots like an atlas or close enough that I enjoy running it. Weather you are shooting from behind a rock or rolling through a brawl you can always put out good damage at most ranges and it dose not have any heat problems, not even on caustic....This I like.
  9. Marukeru
    Marukeru Benefactor
    Sounds like I'll have to upgrade to this loadout to run with Tuku. My 3X LPL is fun, but, I like this builds speed and versatility in range.
  10. NoobWeapons
    NoobWeapons New Member
    *CHUGA CHUGA CHUGA CHUGA*
    That is all...
    :D
  11. Psychobunny
    Psychobunny New Member
    this is kinda funny, was looking for builds for catap and dragon, and found this build wich is what i have ben having for quite some time, cool, turns out i have a good build than lol.
    im new here, 1st post, had to register when i saw this lol..
  12. Michael
    Welcome to the MechSpecs community!
  13. TruePoindexter
    3x UAC5 is quite popular though I would be worried that's not enough ammo. I used to run 2x UAC5 on a CTF-3D with 150 shots and usually was out of ammo before the end of the match.
    Ammo is consumed in order of danger so the CT ammo gets consumed first. I figure that it's safe there as when my CT is vulnerable I've fired off those two tons of ammo first. If not - I've done something wrong. At the time I made this build UAC5's were bugged and would jam for the entire match. The standard AC5's were a stop gap that I ended up preferring.
    Yup that's the idea. You're toughish while being relatively fast. You can output good damage at almost all ranges under any heat condition. Glad you liked it!
    With the changes to heat on energy weapons I'd be curious about how that would work.
    It's a wonderful sound :)
    Welcome! I've found it's solid and easily underestimated.
  14. dude2976
    dude2976 New Member
    Swapped the 320XL out for a 300XL because i don't have enough cash yet for the 320Xl
    by doing this was able to fit an ams with 2 tons of ammo and some extra leg Armour
  15. dude2976
    dude2976 New Member
  16. TruePoindexter
    Cool! How's it working out for you? If I could make a suggestion it would be to move the AMS ammo to the arms. In the LT like that you run the risk of an ammo explosion (AMS ammo is treated like MGun ammo in this case) so it's safer out in the arms. It's much safer there and in a worst case you lose your ammo due to an arm being destroyed which is preferable to sudden death due to an unlucky ammo crit.
  17. Tsume Eiranis
    Tsume Eiranis Well-Known Member
    184
    I also run with a 300 XL, AMS and 1 ton of ammo for it.
    This 'Mech works like a charm, love the damage I dish out... though I have to be wary of overconfidence, I sometimes find myself going head to head with assaults.
  18. TruePoindexter
    Haha yeah it's not really intended to go toe to toe with something much larger than you :D
  19. Rusty Knuckle
    Rusty Knuckle New Member
    absolutely love this build. only have one question. chain fire on the ac-5? or keep them together?
  20. Business
    Business Advanced Member
    270
    My first round of being able to get involved in some fights turned out great---I have the 300XL version and running 14 DHS which allowed me to pour on the damage against mechs who shut down. Quite the advantage! I haven't done over 800 damage in much of anything besides my Dragons in a long time
    I'm amazed at how many good builds this chassis has (ERPPC/AC10/MLAS is a favorite) and this build gets a full rating from me.
