This is a contest: Who can post the "one" build with the highest possible Direct Firepower on the Shadow Hawk? Condition 1: Armor > 100 Condition 2: Ammo each Cannontype > 1ton Condition 3: Cool Efficiency > 20% (upcoming variants can change the "one" build) Good Luck & Have Fun! Blagg
http://mwo.smurfy-net.de/mechlab#i=50001&l=33c674f6f6fd633fc066c6dda1307a85d4194524 Best I could manage.
thats very very close to the maximum.. i have one build here, where i have 56 Firepower.. but i believe there is something even above 60 Possible! i can beat your build by only changing the ERPPC to a LPL: http://mwo.smurfy-net.de/mechlab#i=50001&l=5fb2f9c2e874f9c46560d7d763f3e95fcfc2472c ow here is my attempt: http://mwo.smurfy-net.de/mechlab#i=50001&l=aac53c626b0cbc3efe55a804950ab5590db640af but i still believe there is something beyond 60 possible!
Ahm.... http://mwo.smurfy-net.de/mechlab#i=50001&l=f025aa9fc94105cc66b9c6daad14c6427c197f6c If it's 60 you wanted, you should ave said so.
can you go up to 65 ? i believe its also possible! try to get your Armor down to 100, Cool Efficiency down to 20. You still have so much tons to get freed.
http://mwo.smurfy-net.de/mechlab#i=50001&l=ebf64e6ecb0c445179d4f3c53c35860d83dd2b1f It breaks your rules, but it is so close to that 65.
http://mwo.smurfy-net.de/mechlab#i=50001&l=5f38bd1311172bf19ecbdf73aa1e5a166087c6a8 slower than an Atlas. better know how to dodge.
lol, i was thinking 30% heat for some reason. my mistake. too much min/max in my head for these contests.
ya i tested it man. Remove everything but actual weapons from the mechlab and just put the highest direct firepower weapons you can put in there and this is what you will come up with that still fits into your rules.
a MLas and higher engine is actually possible and not so slow with tweak could actually score some kills if one would want http://mwo.smurfy-net.de/mechlab#i=111&l=ea2cc815ce42536e1f1193a340d52b6f268664ea if SRM buff will make them all register, this could acually kills most mechs in a CT shot point blank ! Can go over 80 but efficiency is 20 and not >20 (removed smurfy link)
79.60 seems to be the max then so far. the last one is too hot (at 20%) also the armor count is too low (at 1 ton) Damn, once again proves that us Mechbay Warriors are crazy.
http://mwo.smurfy-net.de/mechlab#i=111&l=a2b9257c5d0171c525520df483e7301c0766eb6a With 3km/h less you can as well jump! can alpha strike 2 times in a row without overheat !
