Casual HGN-IIC-Keeper "Scottish Blaster" (1xcUAC20, 1xcUAC10, 3xcATM9, XL320)
Thread in 'Keeper' started by Falconium, Mar 17, 2018.
  1. Falconium
    This thing was on sale and I couldn't resist. It just looked too tempting.
    I designed this build to try to balance DPS, alpha, along with a general mix of close to mid-range firepower. The speed is (almost) maxed, it has plenty of ammo for all 3 weapon types, and the heat efficiency doesn't look terrible, at least on paper. I have yet to run it, but I intend to post results soon.
    If this doesn't work out I'll probably switch to something more ATM focused, with just an LBX20 or something on the side. But we'll see.
  2. Shock
    875
    356
    That looks fun but hot, especially when you get into double-tapping. I might try it with LBX instead of ultra ACs. I made this quick and dirty as an alternative. It's probably a little light on ammo.
  3. Aylek
    This.
  4. Falconium
    Yeah I actually took the UAC version into Testing Grounds last night, and yes, it's quite hot. I likely will switch it to your version, though I want to try the original build in a real match at least a few times before giving up on it. Because science. ;)
    And your ammo values are essentially the same as I'd keep them.
  5. Excalibaard
    5,179
    Maybe 2uac10 and atm27 would be a nice alternative besides lbxes
  6. Falconium
    I also like that as an alternative. Allows for more DHS too, so it runs more efficiently overall.
    Probably gonna have to try all of these. :D
