5/5, OP weapon loadout is good, but it could be improved: by swapping Ferro with Endo, you can add more DHS, add a single JJ for quick-turning and a TC1 for slight more projectile velocity and crit chance. Build is very solid with decent pinpoint, with more DHS is cooler (also due to recent cERPPC nerf to 5 seconds cooldown instead of 4). The JJ also helps to quick-turn and shield with the empty but armored left arm.
5/5, This build is solid. The arm-mounted AC's are low and wide, but they are manageable. Maintain standoff distance and land alpha double taps. My take on it: _ https://kitlaan.gitlab.io/mwoskill/...062101cf37f0000e86f773f21c3a0af271b#s=Weapons
