Maxed ammo skills are a must-have: don't bother with this build until you unlocked those nodes. _ The biggest feature of this mech is the overall balance across weaponry and utility: 2 decently high-mounted ERPPCs combined with 3xJJs will grant you decent poptart capabilities before the brawl starts to soften up target and hopefully to mostly free trade against any opponent, while LBX20 and 4xSRM6+A should be able to kill up to non-meta-brawler heavies. Just be mindful ammo count is REALLY low, so don't use this build as a pure brawler, but use your weapons depending on position and range. Always prioritize sniping with PPCs over brawling due to your ability to free trade while poptarting and the lack of ammo. Also, if you split those 2 roles, you should achieve a ~60% cooling efficiency if you either fire 2xERPPC or the 1xLBX20+4xSRM6 combo. Alpha strike only when you are completely cool and in a dire situation (pun intended. ALT: swap ERPPCs with LPL if you really don't like the PPC travel time or the extreme heat, but IMHO is not really worth it. _
