The only reason to use the Standard version is to keep a little more survivability ( mean you keep full speed with one torso down ). But you have to reduce the power of engine to the start. The advantage of cooling is 32 vs 31 % . But you gain 4.8 of speed. The XL is the best but i use the standard in my video. I want use endo steel in other build i will use with this mech. I dont want remove endo and buy it again after.
5/5, Like Flokoloko said, with a cXL325 this build is a beast. The TC1 is a must for slightly better projectile speed and a boost to crit chance, which is further enhanced by the PPCs high damage: if you get a crit, it will probably blow up. Plus, this mech gets a 45% bonus to acceleration and deceleration, further enhancing peeking. If you are playing on cool maps, you can fire 8 PPCs in total if grouped by 2 without overheating. A dredful sight considering the excellent alfa and the very long range. Spoiler: Two good matches
