HBK-IIC-B "Lampy's SRM Brawler" (4x cSRM6+A, 2x cMPL, 4JJ, cXL275)
4.5/5,
Thread in 'HBK-IIC-B' started by lamppost, Dec 18, 2015.
  1. lamppost
    lamppost New Member
    Great brawler. Fast @ 96kph, High flying with 4 JJ, hard hitting @ 64 alpha, and amazingly heat efficient. I am loving this mech!
    LesserDaemon and Cpt Chattahah like this.
  2. SP3CTREnyc
    SP3CTREnyc Junior Member
    45
    Why not SPlas and a TC1? You lose .16 max DPS but gain 6 seconds of fighting and a higher crit rate owing to the TC and the SPLas cooldown.
    You should also know that with the SPLas Range 5 mod and TC1, the max range of CL-SPLas is 340 with an effective range of 191. Just something to consider.
    Even if you wanted to keep the Ferro, you could add more ammo and armor.
  3. PyckenZot
    After the first few fundrops in the Lurm version of the IIC-B. I moved to this build. Solid, SRM platform.
  4. Shock
    Shock Patron of the Underdog
    758
    317
    168
    I run it with 2 ERML instead of 2 MPL and add some cooling and armor
    War 4H likes this.
  5. Aylek
    Optimized SPL version. Never ever load your ammo in the legs when piloting a medium mech. Also, a TC1 for just 2 SPL? Nonsense. Buff your armor if you want to brawl!
  6. enileph
    What's the difference between Side Torso and Leg ammo storage when you have a cXL?
    I would agree if it is IS mech but not clan.
    Clan mech have CASE in all parts anyways, if anything the leg is safer than the Side Torso where it is part of the engine.
    You blow off a leg and some ammo. A Side Torso crit would take some engine out on top of weapons and ammo.
  7. Aylek
    Because you can't run away with a leg missing, but might survive a fight with a torso blown away. Simple as that.
  8. War 4H
    War 4H New Member
    I prefer the 2 ER Med. build. Very efficient.
