It still needs to be tested, but on paper it looks good. Play it like any other vomit laser / peeker / poker you ever used, except this one is gonna be extremely hot. If you need to shield, use your right side and protect the mediums. Except for the range, the left side with medium lasers has slightly less damage and heat generated, but has way better cooling power. If you prefer the other way around, swap heatsinks and armor accordingly. Skill wise, you should max out operations and grab any heat gen bonus along with laser duration.
