The "Hit n' Run" was my first robot and still one of my favorite workhorse mechs that can get in, do some damage and get out before taking too much in return. The 2xLL in the multiple DHS configuration allows them to be fired whenever they are off cooldown. This is the bread and butter damage for the robot as it gives you a decent punch plus good range and freedom to move while firing, which is what needs to happen with any medium. The 2xSRM4+Arty are for those "Get out of my face" moments when some big Assault thinks you are a run of the mill hunchy and not the great pilot you have to be to run this robot. It is also great for taking advantage of the position you will have because you never stop moving during the match to protect that XL. PROS Max speed for Hunchback - 98kph Mix of long range and short range weaponry for maximum engagement distance No "lock on" requirement to use the weapon systems Excellent Heat Effeciency AMS CONS XL Engine. Do not be scared. Just play smart Low Alpha - 34 is not that great. Stick and move for greatest effectiveness.
