HBK-4P Techwalrus' Cinder (8x SPLas, STD275)
4.5/5,
Thread in 'HBK-4P' started by TechWalrus, Nov 7, 2014.
  1. TechWalrus
    TechWalrus New Member
    Modules: SPLas Range 5, SPLas Cooldown 5, Coolshot 9, Coolshot 6, Adv. Seismic Sensor, Radar Deprivation, Target Info Gathering
    The fully mastered Cinder surpasses a Cinder that is not mastered.
    7.38 DPS when the above criteria have been met.
    This mech is without a doubt the best hunchy I've ever seen or built. It is good on heat and it kills everything that gets too close. I have taken down direwhales with this monster of a hunchback. The biggest difference I see is that it is a STD engine and not an xl. That means you can still use that left torso as a shield (Primary use the arm). I went against a DW friend on a private match, killed him multiple times. I want to post these videos but for now I'll leave you with some screenshots. If you run this build please let me know your thoughts.
    All of these screenshots were taken from today. I was working directly with my direwolf friend Krivz.
  2. enileph
    Go all the way dude.
    vanel, epikt and Blagg Zear like this.
  3. Blagg Zear
    I ran tried this here in the past. Worked pretty well unless you get sniped from distance..
  4. dranozir
    Good build but small pulse have a very short range.
  5. Excalibaard
    4,609
    1,006
    That's why they're balanced instead of broken :p
    I like the idea of the OP better than the 9 pulses. That way you can obsolete an otherwise useless arm, and get 2x DHS back from 1 SPL. This allows for more alphas that you can get off before you overheat and being an even more oppressive scalpel. Personally I'd probably still prefer to run ML+SPL for the range advantage, but full SPL is not to be underestimated :)
  6. Ragnar RedHawk
    Ragnar RedHawk Well-Known Member
    141
    DPS is crazy
    dranozir and Excalibaard like this.
  7. Badger
    Badger New Member
    Fun build. I have found that using a LT engine frees up room for a AMS and the full 9 SPL's adding to its survivability in todays LURM filled matches.
