Casual HBK-4P "Revenge of the Single(HS)" (1xLL, 6xERML, TC1, XL255) + alts
Thread in 'HBK-4P' started by CarloArmato, Jun 24, 2018.
  1. CarloArmato
    1,742
    517
    Coolest meta vomit laser build ever made. You can't achieve the same heat efficiency with a LE and DHS
    And unluckily there is consequently no point to use an XL275 with SHS: you achieve the same cooling efficiency with the LE DHS build
    Why XL? Because if you lose a side torso, you ain't gonna nowhere anyway.
    Right torso loss? 1 ERML to fire
    Left torso loss? -4 engine HS and -6 SHS... The remaining HS won't be able to sustain the whole build
    Why this build? Because you can alpha strike 3 to 5 times without overheating, depending on the map... Seriously, though, 5 times in cold maps and 3 times in very hot maps.
    Replace TC1 with armor if you feel you are too squishy or you get Headshotted too often.
    ALT: XL255 with AMS, because why the hell not? It does have the same cooling efficiency that the LE275 version but has missile protection
