HBK-4P "Expert" (6x MPLas, 2x ERSLas, STD250)
Thread in 'HBK-4P' started by Ragnahawk, May 28, 2017.
  1. Ragnahawk
    Ragnahawk Well-Known Member
    219
    Update 7/20/2017: Changed to ER small.
    Max range: SLas 172 m, MPLas 253 m
    Efficiency Skill Tree: Click Here!
    Atlas Armor Skill Tree: Click Here!
    Groups:
    [1] Alpha strike
    [2] 6 MPLas
    [3] 6 MPLas (chain-fire)
    Proof?: link
    If you were using 6 MLas 2 MPLas before ( :meh:The weapons got linked together:vomit:), with this build you are trading a little bit of range for better heat efficiency (By 4 heat), cooldown and duration (25%!!). Just spam the alpha button as fast as you can if you don't believe me.
    side note: if you put 25% duration on medium lasers... :rofl: it just turns into a medium pulse laser. who would've thought.
  2. Ragnahawk
    219
    updated skill tree. Anchor is very important.
  3. Excalibaard
    5,272
    Recently also switched to a MPL-based hunchie. I prefer to run a little faster, so I run only 15 HS and a single ML or Flamer instead of the 2 smalls, which allows me to put in ferro fibrous and a STD275 (which contains the 15th DHS)
  4. Ragnahawk
    219
    In the past, I used to run a standard 270 with 6 medium lasers and 2 medium pulse. So I understand where you are coming from with the speed boost. Until recently when the engine desync came into effect I learned very quickly that the engine I used to run for its benefits was a waste of firepower, for a 10 kph boost. With the skill tree I've created above you might feel that agility that I think your hunting for. Maybe this build might even grow on you.
  5. Ragnahawk
    219
    You might like the xtra punch. It can save you some eye strain.
  6. Excalibaard
    5,272
    The extra punch is at a different range though. If I want to scalpel off some components from 250-300ish meters and stay there, the smalls are disappointing :p
  7. Excalibaard
    5,272
    With the ER Smalls from the new tech I think this will be a great upgrade :)
  8. Ragnahawk
    219
    I was on the fence on that before because I didn't want to go half speed. Now I just adjust to keep my LT barely intact.
  9. Excalibaard
    5,272
    This is what I run it like now. Found the STD250 a tad slow and the armlaser (with protective armor and everything) to take up too much space.
    pic below is without strikes.
