HBK-4P “I’ma firin all ma’lasers!” (6MPL, 1ERSL, 2ML, XL265)
Thread in 'HBK-4P' started by ShiverMeRivets, Nov 4, 2019.
  1. ShiverMeRivets
    214
    49
    The discussion with @CarloArmato and @renzor51 in the “Simple slaughter” build thread gave me this idea to a 9 lasers, no ghost heat build.
    HSL+2 for ML means that we discount 2 MLs when checking for ghost heat.
    So...
    6 MPLs, 1ERSL (syncs well with MPL), and 2 MLs in the arms should not generate ghost heat. BEHOLD the 50 points* pinpoint alpha of the 50 tons mech!
    *rounded up to the nearest integer.
    Note: theory crafted, to be tested.
    Heat should be OK for a few alphas, then if in a brawl use the MPL+ERSL only and add the arms ML as heat allows.
  2. CarloArmato
    Unluckily this build should trigger ghost regardless of your workaround. If I remember correctly, HSL quirk bonus work only when all weapons fired are similar: if a weapon differs from the quirk, it will trigger ghost heat (for instance, RFL-IIC has a +2 LPL HSL, but you still can't fire 2xLPL + 2xHLL simultaneously).
  3. Shock
    875
    356
    I'm not sure about that. For instance, the ERPPC quirk on Marauder 2 4L works with ERPPC + Gauss combo
  4. CarloArmato
  5. ShiverMeRivets
    214
    49
    Tested - this does create ghost heat...
    Please delete this thread :(
  6. Shock
    875
    356
    I liked this post but I was sad about it
  7. renzor51
    renzor51 Advanced Member
    393
    Medium pulse lasers aren't included in that HSL. It only applies to ML's and ERML's, which I know from experience that you can mix on this chassis under the quirk.
