HBK-4G BFG Striker (1x AC20, 3x MLas, STD250)
8 ratings
Thread in 'HBK-4G' started by Random Incarnate, Mar 30, 2013.
  1. Random Incarnate
    Random Incarnate New Member
    Essentially just an optimisation of the stock, but here's what you can do. I hated this (poor Founder choice) variant for a very long time, until this double XP weekend, when I figured I'd master it. Crammed a STD 250 in, up from 225 by dropping AMS and adding FF. You run around, shoot people in the face, and make 150-200k non-premium with the founder's bonus. Highly mobile AC20 platform, great for legging lights, shooting meds in the back, and taking out the sides of anything bigger. Heat efficient, fire the AC20 at will, and don't lean on the lasers on high heat.
    Show no fear, be that plucky little 50t 'mech that runs up to everything and tears off limbs - run away when they look at you too hard.
    I'm 11k past Master now, and I just can't stop playing it.
    [size=14pt]MECHSPECS GAMEPLAY VIDEO
  2. Excalibaard
    5,153
    Same 'I hate my founders choice' problem here, and replacing with a gauss didn't really solve my problems ;)
    Will give it a try. Have started to get okay with the AC20 on my FLAME
  3. Regina Redshift
    1,293
    Totally trade the MLas for CASE and a SLas.
    Edit: Strike that. The SLas I proposed just doesn't pull its weight.
  4. NamesAreStupid
    NamesAreStupid Active Member
  5. skribs
    skribs Min-Max Maniac
    1,688
    Names, the build you linked to could be done much better on a Cataphract (read: with 2 more MLs and still better heat efficiency).
    The OP looks like a pretty good build for the 4G.
  6. Marukeru
    Marukeru Benefactor
  7. Spank n Uranus
    Spank n Uranus New Member
    Just wanted to say thanks for posting this build. I hated playing this mech before. I played a dozen or so games in it, stopped, and just concentrated on my other founders mechs. I did this build and have had a blast over the past few hours playing it. It's easy to get in trouble, do some damage, and get out again if I want.
  8. Anunaki
    Anunaki Active Member
    50
    I can't seem to get this to fit. Has it changed with a patch? If I switch to Ferro, it wont let me fit in a Standard 250 or anything else because not enough slots.
  9. Dwergi
    Dwergi Well-Known Member
    112
    Make sure you full strip the mech. I often forget a ton of ammo in the head and wonder where the extra ton went. Also remember to drop 8 tons of armor off each leg.
  10. Anunaki
    50
    Weight is not the issue. It is slots. If I try to switch to Ferro, it tells me I don't have enough slots. If I take engine out and then switch to Ferro, it will not let me put engine in due to not enough slots. I have plenty of weight to go.
  11. Mythweaver
    Mythweaver Advanced Member
    400
  12. Dwergi
    112
    wc5b, you've got something wrong. Strip the entire thing - because I guarantee that you've got a double heat sink somewhere or some extra ammo if you can't get FF on it.
  13. Gremlich
    Gremlich New Member
    53K past Master.
  14. Erwiin
    Erwiin New Member
    My setup is similar, so I won't start a new post, except that I drop the head-mounted Medium laser for an extra ton of AC ammo.
  15. Blagg Zear
    My "Critseeker" version:
    Blagg Zear
  16. Michael
    I've been using this badboy while grinding my G(F) and guess what?
    PUG match what what?!?!
    This thing can dish out the pain!
    5/5 from me. Even with just BASICS covered it still runs quick, fights hard and stays cool. For 50 tons of awesome this is what you get!
  17. Apnu
    Apnu Active Member
    99
    I run this on my HBK-4G, same thing as OP. This build is a beast! Keep to the middle of the pack in the early game and/or find a good hiding spot and wait for the mid-game action. Then pop out from behind cover and bring that AC20 hot and fast. I call this mech "lil' mugger." By the endgame this mech mops up the other team. This has the strongest finishing power of all hunchies i have, Including the HBK-4P with 9 medium lasers.
  18. Gremlich
    Gremlich New Member
    I don't have FF on my 4G. has it made any difference with your surviveability?
    Mason/Michael, I see you got 802 with that. I got 800 in mine using this HBK-4G with a Logitech JS and a Razer Nostromo
    [​IMG]Uploaded with ImageShack.com
  19. Apnu
    Apnu Active Member
    99
    After experimenting with the 4G a lot, I found this (the OP's) build, and it by far is the best build for this chassis, and my favorite build in the whole game. I call mine the 'lil mugger' because I wait for the brawl to start and the flank into the melee and mug kills.
  20. enileph
    Bumping up the classic builds.
    Probably need 4 tons of ammo on a long fight. But STD 250 is about right.
