Casual GRF-2N "Cat Ghost" (2xERML, 4xSSRM4, ECM, JJ, SA, XL280)
Thread in 'GRF-2N' started by Ch_R0me, Apr 29, 2021.
  1. Ch_R0me
    Ch_R0me Benefactor
    287
    Intended for going "quiet" around battlefield and pick up enemy lights. Would be a bit better if we had EC (Endo Composite)...
  2. Shock
    876
    357
    Stealth armor isn't a very good mix with Streaks as you can't get a lock with Stealth on unless you're in the enemy's lap. Also, that's probably way more ammo than you need. But if you want to keep the Stealth, I recommend going with a mod like this
  3. Please consider using a TAG to counter a stealth enemy.
    I have to recommend using a build with streaks without it. It is very common to have multiple stealth lights in a match.
