Similar to multiple other -1S configs, this one incorporates a Light engine and Light FF to provide Artemis and more speed without using an XL engine. Using ER MLs is of course an option, since they weigh the same. Alternatively, one additional heat sink can be obtained by dropping the engine to 295, removing one heat sink, and by not using Light FF:
Hmm. I feel like there's a bit of a contradiction between short range missiles and extended range lasers. Like you're unsure if you want to be a midrange fire support or close range brawler. I'd go for regular medium lasers (or medium pulse if you can scrape up 4 tons from somewhere) for the brawler role... For the midrange, you could try Medium range missiles instead of SRM, but idk...
Even if you're going for optimal range, rather than maximum range? EDIT: Well, I edited it regardless.
