Golden Boy "Mobile Fire Support" (5x LRM5, 2x MLas, TAG, XL290)
Thread in 'Golden Boy' started by Todo Ringman, Feb 17, 2014.
  1. Todo Ringman
    Todo Ringman Junior Member
    39
    I really want to get the golden boy, they better put it on sale soon!!! :-0
  2. enileph
    You can do something similar with KTO-18
    Basically does the same thing, but faster.
    Only difference is LLas or 2x MLas.
    Cooling is similar enough for you to not worry about it. You don't use the Las and LRM at the sam time usually.
  3. Todo Ringman
    39
    Yes but you do get a C-bills boost when you use the GB instead of the 18.
  4. Todo Ringman
    39
    And if you dont want to use lls then you need the extra laser slot for 9 points of damage 1 tage at least 25 missles and a speed of at least 81 for Mobile fire support.
  5. Merciless Hunter
    Merciless Hunter Junior Member
    Can't wait to see this in action
  6. Aylek
    Coming from the 'Golden Twinkle' I reworked my GB more and more, especially for the current tournament.
    Next revision, especially tweaked for the tournament. Works. :D
    Roosterfish likes this.
  7. Aylek
    XL275 / 280, more ammo and a TAG. Perfect medium LRM machine.
  8. Roosterfish
    Roosterfish Well-Known Member
    121
    Aylek, hats off to you Sir. You just might have made the ultimate Butthole build. The only tweak I can see would be to drop 1 ton of Ammo to up the engine to max and that is just a maybe.
    Aylek likes this.
  9. PyckenZot
    This build is so effective the enemy will call your team a bunch of noob LURMers even though you being the only missile spewing enemy they face.
    True story despite me having forgotten to screencap it,...
  10. Aylek
    I have to remember this quote if I am in need of a new forum signature. :cigar:
  11. McMatt
    McMatt Benefactor
    54
    Something like this?
    AM182051|2@|2@|i^|Qgpa0|2@|i^|i^qa0|Z<2|[O|[<2|jOrT0|2@|2@|Y?sT0|=@|Y?tY0|[O|[OuY0|[O|[Ov60|[Ow303030
    kto-gb
  12. Shock
    875
    356
    I would drop DHS for more ammo. And you can use LFE 280 for the same weight as 275.
    McMatt likes this.
  13. McMatt
    McMatt Benefactor
    54
    Thank you!
