Ghillie "RACked" RAC2 2xLL 2xersL XL250
Thread in 'Ghillie' started by Alloh_BR, Jul 22, 2018.
  1. Alloh_BR
    Alloh_BR Active Member
    Adding new tech to an old classic, and it works great!
    use the RAC2 as machineguns... the main weapons are the Large Lasers, I only use the ERSLs when the RAC jams, or am out of ammo (2t)
    To get better heat, replace the ersL with regular sL, specially with the variant using RAC5.
    You can also try to remove the ECM and become RAC5 2LL 2SL , quite deadly but HOT!!
    (Ammo placement is for clarity. Move it to where you prefer)
    Copy and IMPORT directly:
    AX8:20d0|DdpU0|^<2|i^qU0|[email protected]|[email protected]|i^rO0|`?|`?sO0|[email protected]|i^t\0|?Pu\0|?PvB0w<08080
  2. Alloh_BR
    RAC5 variant:
  3. Excalibaard
    4,841
    1,072
    I think the LLs are too heavy to use with a RAC on a 50 tonner. leaves you with too little tonnage and space because of the DHS/Endo.
    Maybe on a bigger chassis, but here I'd do 1 LL at most, preferably just 4ML. Otherwise, get rid of the RAC and just do 3LL 1ERML :)
  4. Alloh_BR
    Try, and you'll realise that the RAC2+2LL version works fine... and again, either shoot RAC, *or* the small lasers...
    And that's the beaty of this build, the 2xLL makes the difference, better than RAC5+4xML!
