FS9-S "Nolurm" (5x MPLas, 2x AMS, 2x JJ, XL280)
4/5,
1 rating
Thread in 'FS9-S' started by Nori, Jan 26, 2015.
  1. Nori
    Nori New Member
    So I'm thinking of making this build with my newly bought FS9-S. I already have the FS9-H skilled up, but I not infrequently felt like a little AMS would be helpful so I thought why not try utilizing the dual AMS this can do.
    Good idea? Bad idea? Not sure yet.
  2. Motörhead
    As a light you will be often the last mech and so you can use dual AMS potential.
    Due to this aspect, I'd do a minor tweak, dropping 1JJ and adding 1/2 AMS ammo.
    Anyway, the build looks solid.
    The weapon placement is also nice for peeking over a corner or a building.
  3. The Verge
    I'll test this, as I've been looking for a faster build for this mech.
  4. The Verge
    This is what I've been testing, and it works great! the max engine really helps me out, being able to go 150KPH in a light is always great!
  5. The Verge
    A good build, but skip the AMS for the max engine and extra JJ.
  6. Big Rico
    Big Rico Active Member
    69
    I've been running a mix of fx8230 and Vergere, with max engine, a shield arm, and 1x AMS.
    So far I'm liking it. I mainly run it this way because I already had the xl 295. When I get around to having some spare C-Bills for xl 280 looking forward to trying these other builds on here. I also want to try an xl 270 with 5mpls, 3 DHS and shield arm later on.
  7. MightyBolamite
    MightyBolamite Junior Member
    Decided to pick this variant up as it was the only one I didn't own. Liked what Vergere had here and built it.
    It's a beautiful little machine. No elites at all and I usually score 1 or 4-5 kills (plus assists to match) per game. It is quickly becoming one of my favorites.
    Only thing I don't like about it is the range. I find myself firing when I can't hit the mech; too used to Larges I guess. Might be worth the range mod.
    Just don't forget your light creed and you'll be fine:
    Armor is a lie, there is only speed.
    Through speed I gain ground.
    Through the ground I cover, I gain a flanking position.
    Through my flank, I sow confusion.
    Through the confusion, my team gains advantages.
    Through the team's advantage, I gain victory.
    The speed shall set me free.
  8. Aylek
    You probably should use 4x MPLas (arms) + 2x SLas (torsos) when doing the double AMS thingy. That way you retain a lot of firepower while also bringing enough ammo for the dual AMS.
