_ Actually decent enough build. ECM, ok mid range damage, great short range alpha. Cooling is good enough. Now to take it beyond reasonable. _ You can safely alpha with skills. You can even get off back to back MRM shots. 240 damage at 600 meters. Not bad. But also, not good. Not enough cooling by far and low on ammo. But if someone turns their back to you. Somewhere in between _ _ _
