Casual FNR-5 "Wingcrab" (4xUAC5 3xML ECM LE300) +Alt (LE280, LE325)
1 rating
Thread in 'FNR-5' started by Excalibaard, Apr 19, 2018.
  1. Excalibaard
    4,300
    936
    219
    Inspired by my KGC-000B, 4 UAC5 3ML is a fun loadout. Add ECM and higher mounts, and it may be worth it!
    Cooler:
    Faster:
  2. Shorvok
    Shorvok Junior Member
    I've been trying various builds but it really does seem that quad UAC5 is the way to go on this mech if you want to diverge from the HGauss.
  3. Jesse Custer
    Jesse Custer New Member
  4. Excalibaard
    4,300
    936
    219
    That's fine, I personally like the extra hitscan, and they do jam quite often for me ;)
    With each gun having 15% chance to jam, the chance that at least one jams after the first double tap is 1-(0.85)^4 = 48%, after the second double tap it's already 1-(0.85)^8 = 73%. I think you're extremely lucky :)
  5. Jesse Custer
    Quite possibly. It'd be the first time since I've started gaming that RNGesus has favored me. :D
    That said, I'm probably going to try one of your builds with the backup MLs. Can't hurt, right?
  6. Excalibaard
    4,300
    936
    219
    certainly can't hurt. helps with taking down UAVs as well as finishing red components with hitscan. I've made a small adjustment after ammo skills made the 8th ton of ammo in many cases a bit too much to use. Running a TC1 instead now :)
    Jesse Custer likes this.
  7. Dagonus
    317
    90
    146
    Okay. This is the Best FAF5 build I've played yet.
