How I run mine. Put the MPL in the torso first, then the LPL so your longer range is mounted higher. LPL range module helps. Watch the heat, but Alpha and move if you can. Shield with the right side (which is often tageted anyway since that is the ballistics side) Buttons 1: LPL 2: MPL 3: Chainfire MPLs (controlled heat damage)
