Kick! Punch! It's all in the mind. If you wanna test me, I'm sure you'll find. The things I'll teach ya is sure to beat ya. But nevertheless you'll get a lesson from the teacher. Kick, Punch, Chop, Block. I know it's not your usual build, but, with Pulses, you still get some of the quirks - as well as faster duration. Then with the LBX, you can MASSACRE the remaining forces. You have enough ammo to even poke at enemies long range. This is MOST DEFINITELY a support build to the enth. This is meant to stick with your brawlers and assaults and wait for enemies to come to you. Your MPLs give you decent range, but, when you can get into close range brawling range, this will truly come into it's own. High DPS, high crits, high ammo, mid-speed, decent alpha with a quick recharge and enough JJ to hop an Atlas! Go forth and escort! I realize a BJ-1 can do a very similar role with the same speed and effectiveness (sans one laser) but, the Enforcer just makes such a great little tank with proper twisting. Seems proper.
