1. Dear MechSpecs visitors!
    To help pay for the hosting, an extra ad slot using Google AdSense's new 'AutoAd' system is being tested. This is only enabled for our (many) guest visitors, so register an account and the site will be back to how it was. Let us know if these ads get too invasive, as user experience is of course top priority!
    --- Regards, the MechSpecs team!
ENF-4R "One-Two Punch" (1x Gauss, 5x MLas, 2x JJs, XL260)
3 ratings
Thread in 'ENF-4R' started by flador, Mar 4, 2015.
  1. flador
    flador New Member
    This was just the first build I came up with when I saw this mech. It has the max engine rating, decent jumping, a gauss for sniping and general no-heat damage, and 5 medium lasers for stripping armor. Overall this mech performs well at any range, and is as mobile as I could get it. Feel free to change the armor distribution on the torsos; they're at the default values from when you max it.
    Here are the stats from my first game with this mech:
    As you can see, it performs beautifully!
  2. Durandal
    680
    If it works for clans, it works for IS. Gauss and 5 mediums is a solid build for any mech that can hold it, especially if it can maintain good speed.
  3. Sir Tiddles
    Sir Tiddles Active Member
    96
    This is a great build for this mech. The only thing I would note is that the XL 250 engine comes with the other enforcer model, so I've been running with that and another 1/2 ton of gauss ammo.
  4. Durandal
    680
    In that case, you might as well go XL255...same weight, better speed.
  5. Sir Tiddles
    96
    I'm only noting the XL 250 as it comes standard on the other enforcer model, so you don't have to buy another expensive XL engine if you're just leveling for chassis mastery or don't have a lot of extra CB laying around.
  6. Aylek
    2,753
    513
    My version of this variant, which uses the stock engine.
  7. CarloArmato
    1,075
    325
    165
    New tech version with Light Ferro (+0.5 ton) and ERML for increased range.
    Ballistic Cooldown− 20 %
    Energy Cooldown− 10 %
    Energy Range+ 5 %
    Large Laser Range+ 5 %
    Base Structure (LA)+ 8
    Base Structure (LL)+ 12
    Base Structure (RA)+ 8
    Base Structure (RL)+ 12
    Due to current quirks, it is better to focus on cooling for maximum DPS and due to the fact the build will be hotter than it looks (-10% energy cooldown)
  8. CarloArmato
    1,075
    325
    165
    Solid build. A bit too squishy due to lack of speed and armor / structure quirks, but it can pinpoint very well and is somewhat cool even without skills.
    TIP: don't trade with anything that can clearly outgun you AND try avoid trading with more than 2 targets at once, so you will be able to win most trades.
