High alpha, mid to short range assault that probably needs a favorable map to function well. Ammo count is low, but a lot of damage comes from energy. You still have significant fire power after you run out of ammo. Needs all the heat skills. You can alpha and keep on the UAC10s until the PPPCs fire for the second time. Then you need to be back in cover or really need to manage your firing well. https://mwo.nav-alpha.com/mechlab?b=ece20179_DWF-W Quirks HEAT-12.5% WEAPON VELOCITY+10% BASE ARMOR (CT)+18 BASE ARMOR (RT)+26 BASE ARMOR (LT)+26 BASE ARMOR (RL)+9 BASE ARMOR (LL)+9 B chassis for more heat reduction (15%) and options for another ton of ammo or less heat per alpha. https://mwo.nav-alpha.com/mechlab?b=450368e7_DWF-B https://mwo.nav-alpha.com/mechlab?b=ab867a26_DWF-B https://mwo.nav-alpha.com/mechlab?b=efde7246_DWF-B Trial run Spoiler
