DWF-UV "Cold quake" (8xcAC2)
5 ratings
Thread in 'Ultraviolet Builds' started by dranozir, Dec 25, 2016.
  1. dranozir
    With AC2 you have a cooler build.
    AC2 = 0.6 heat per shot.
    UAC2 = 0.8 heat per shot.
  2. Great build. Very fun.
    Can be directly converted to 8x LBX-2.
  3. dranozir
    Yes at close range LBX2 could be a beast. I want to test that !
  4. 5/5,
    Firepower, range and disruption.
    It will crit you.
  5. LBX version
    BlackCatF, Gun Tuv and Shorvok like this.
  6. dranozir
    You can post this build and give a nickname !
  7. No man. Love the build. Love the name.
    No need for another thread.
    Plus it works equally well with AC2s.
  8. dranozir
    Yeah cAC2 and LB2X have the same heat.
  9. TheOddball
    TheOddball New Member
    Fun to goof around in. Got 1k in my first drop with it. Sadly, still a big target for the other team.
  10. After the latest Clan Skill Tree Heat nerfs, this is still probably the only reason to run a Dire Wolf.
  11. Ruludos
    Ruludos Benefactor
    88
    51
    I guess nobody has shown you the DireWTF yet.
  12. krevLL
    krevLL Insane Fire Troll
    298
    92
    @dranozir posted it(DireWTF) first under a different name, but I keep this as a primary build for my DWF.
    I'll admit that the UV omnipods and AC/LBX2's would be more adaptable, especially in regards to range and sustainability.
  13. Seen it. Tried it. Would rather do gauss-vomit on the Mad Cat Mk II.
    It was the only other build that was even close in my mind. But being so slow and needing to get to 450ish meters to be effective limits it.
  14. Shorvok
    Shorvok Junior Member
    The 8x LBX-2 variant is the only way to run the Ultraviolet.
    So, so good.
  15. Shorvok
    8 LBX is the way to go.
    dranozir likes this.
  16. Axetrain
    Axetrain New Member
    LBX2s are no joke this thing is legit.
  17. May 27, 2018
    AC2s (0.5 heat) are now hotter than LBX2s (0.4 heat).
    LBX2s have 0.35 projectile spread.
    Use with Prime or A variant CT for +8 armor front CT.
  18. dranozir
    Yes cooler ! and no heat penalty
  19. Excalibaard
    4,424
    980
    219
    Better than 8xUAC2 just because of the heat.
