DWF-C "Starkiller Base" (1xcGR, 5xcERLL, 1xJJ, TC1, ECM and 2xcGR, 5xcERLL Alt))
Thread in 'Dire Wolf Omni Builds' started by Remover of Obstacles, Dec 24, 2021.
  1. Starkiller
    A variation from the 6x ERLL builds out there with ECM and a jumpjet. Grabbing both prime side torsos for heat quirks. You can side poke, but Dire Wolves leave a lot of body exposed anyway.
    Weapon Groups
    1. 3x ERLL and GR
    2. 2x ERLL and GR (I pick head and top/interior arm)
    3. GR
    4. ERLL Chainfire
    Typically, I will use groups 1 and 2 and you can keep up fire for a while.
    Interestingly enough, with full skills, you can survive an alpha (at least according to testing grounds). If holding still and not on a bad map, you may even take no damage. Moving at full speed will make that a lot more risky.
    If you are ok with the heat, you can shave armor and a heat sink for a TC3 and boost that range.
    With good firing discipline, you can add another gauss rifle.
    Good CT Convergence
    Good Heat Quirks
    MUST ALPHA MORE!!
  2. The Alpha version with double gauss isn't too bad in the right circumstances.
    It is too slow to get much end of match damage in. :(
    Ended match low on ammo with minimal internal damage. I gotta say it was a good day.
  3. ShooterMcGavin80
    489
    77
