https://mwo.nav-alpha.com/mechlab?b=b13c9426_DWF-C I was looking to do a 4x ERPPC build that used the higher torso mounts, but even with the heat buff in the Oct. 2024 patch it was too warm. The prior clan DHS nerf is still being felt. So, I dropped down to 2x ERPPC and added AC5s. The velocities match well and 5x AC5s are decent when watching heat. ECM helps for setting up along map edges. Take the prime chassis if you want heat reduction. That will give you some tonnage back for heat sinks as well. https://mwo.nav-alpha.com/mechlab?b=fdb468b2_DWF-PRIME
